08-09-2018 02:39 AM - edited 08-09-2018 06:27 AM
Cisco IOS XR / NCS-5500
Q.
Why am I not getting BGP Source origin AS on the netflow monitor-map?
In "show flow monitor MYMONITOR cache location 0/0/CPU0"
BGPSrcOrigAS is always 0
flow exporter-map EXPORTER version v9 ! transport udp <port> source Loopback0 destination <ip of collector> ! sampler-map SAMPLER random 1 out-of 4000 ! flow monitor-map MYMONITOR record ipv4 exporter EXPORTER interface <Peering int> flow ipv4 monitor MYMONITOR sampler SAMPLER ingress
router bgp XXXXX bgp enforce-first-as disable address-family ipv4 unicast bgp attribute-download
network x.x.x.x/xx route-policy <policy-name>
RP/0/RP0/CPU0:xxxxxx(config-fmm)#record ipv4 ? destination IPv4 Destination Based NetFlow Accounting destination-tos IPv4 Destination Based NetFlow Accounting TOS peer-as Record peer AS <cr>
Solved! Go to Solution.
08-14-2018 03:44 AM
Issue resolved.
Turned out to be known issue, needed SMU to be installed.
Cisco: CSCvh68331
08-14-2018 03:44 AM
Issue resolved.
Cisco: CSCvh68331
