We're currently running CiscoWorks LMS 3.2, with CM 5.2.1. According to the data sheets, this does not support Cisco Catalyst blade switches (c3032 as an example). Are there updates or patches that I've missed?
To check for updates use Common Services Software Center , both Device and Software updates. However that siad, if support is added for newer devices then it is reflected in the documentation, so I was assume at this point there is no support.
You should poll sysObjectID (.1.3.6.1.2.1.1.2) for the device and then locate it on the compatibility docs located here.
