06-18-2014 10:32 PM
Hi Friends,
We would like to configure broadcast storm control in our LAN to detect/avoid mac-address flooding. What is the best way and Can I know how to decide the raising threshold & falling threshold values ?.. Please suggest.
S.Tamilvanan
06-18-2014 10:55 PM
the best way is to monitor your network fir 5-6 days in order to find out the normal pattern of broadcast traffic. Then based on results form this monitoring process you can set the thresholds of broadcast traffic.
06-19-2014 02:07 AM
Ok.! How to do that ?. Can you suggest some options or commands.. Please.
06-21-2014 02:37 AM
Any suggestion ?. Please.
06-21-2014 05:38 AM
Try to find a program in order to monitor your network. You can try a free version of netflow in order to check the normal traffic pattern of your network.
