c2960s ethernet management port
bartbruninx
Level 4
Level 4
Can the ethernet management port on a 2960s be used to source syslog, snmp traps, ntp updates... ?
this is not mentioned in the software configuration guide (http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swint.html#wp2220949) and what worries is the instability warning in the bottom..
thanks,
bart
Balaji K
hi Bart,
The Ethernet management port supports these features:   <<< from the documentation...
Express Setup (only in switch stacks)
Network Assistant
Telnet with passwords
TFTP
Secure Shell (SSH)
DHCP-based autoconfiguration
SMNP (only the ENTITY-MIB and the IF-MIB)
IP ping
Interface features
Speed—10 Mb/s, 100 Mb/s, and autonegotiation
Duplex mode—Full, half, and autonegotiation
Loopback detection
Cisco Discovery Protocol (CDP)
DHCP relay agent
IPv4 and IPv6 access control lists (ACLs)
Yes, i know .. Thats why i placed the url.  Just wondering of this interface can be used for syslog and traps without having instabilities?
