09-11-2013 05:19 AM
Dear Friends
I have LMS 3.2 installed to my client. I have 6509 and 3560 devices they are showing in LMS 3.2 cisco View. Recently I added a new 3560 device but it is not showing in cisco view. It is showing with question mark.
I have attached the screen shot of LMS 3.2 devices list and errors.
01. The device list in summary lay view
02. Topology view which is question marked and showing cisco product and other 3560 devices showing correct model
03.I tried to update the cisco view
04. While trying updates I couldn’t update successfully given the attached error. I check the CCO account it is working fine.
05. not showing device sh version
06. Showing device sh version.
07. Attached the psu log also.
Please advise how to update or what to do to bring the device in cisco view ?
Thanks and Regards,
Shahul Hameed.
Solved! Go to Solution.
09-11-2013 09:14 AM
I can see the below exception in the logs:
Exception while downloading CV packages from Cisco.comcom.cisco.nm.xms.vds.VDSException: CvHandler.getFileList:failed to connect to Cisco.com.
Upgarde the LMS to LMS 3.2.1 ,if the issue presist then you may need to apply the patch for BUG :
Thanks-
Afroz
09-11-2013 09:14 AM
Thanks-
Afroz
09-14-2013 10:52 PM
Dear Afroz
Thanks for your advise. After upgrade teh LMS 3.2 to 3.2.1 the device 3560P is showing on topology view.
Thanks and Regards,
Shahul Hameed
