11-20-2021 03:36 AM
Hi folks,
Our C3850 is not properly detected in Cisco Business Dashboard.
The dashboard has the credentials, there is a SNMP V2C RO string in place know by the dashboard, cdp is enabled, lldp is enabled.
Do you know how I could get it properly recognized ?
Thanks !
Solved! Go to Solution.
11-20-2021 09:31 AM
- Ok, for 'bigger switches' you need Cisco Prime
M.
11-20-2021 05:20 AM
is this Cloud or Local?
11-20-2021 05:49 AM
Thanks for the reply.
The CDB has no access to the Cisco servers since this is a closed industrial restricted environement.
I have never played with ACLs before. Do I have to allow something to get it identified in the CDB ?
11-20-2021 09:10 AM
- I thought Cisco Business Dashboard focuses on small business devices , not sure your device is supported :
M.
11-20-2021 09:24 AM
That could be the explanation indeed...
Thanks!
11-20-2021 09:31 AM
M.
