Highlighted
Beginner
C9500-48Y4C Unsupported Cisco Device on Prime Infrastructure 3.6
I recently installed Cisco Prime Infrastructure 3.5 so as to manage catalyst 2k, 9200 and 9500 then upgrade to Prime Infrastructure 3.6 to support 9500 switches.
It appears that Catalyst 2k and Catalyst 9200 are managed correctly and 9500 is shown as "Unsupported Cisco Device".
The part number of the Catalyst 9500 is : C9500-48Y4C
The 9500 ICMP and SNMP reachability are OK.
From the Cisco Prime Infrastructure Device Supported document find here, it seems that this hardware is supported.
https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/supported/devices/PI36-Supported-Device-List.xlsx
Does anyone hit this behaviour ? I don't find any bug document about it.
10 REPLIES 10
VIP Mentor
Re: C9500-48Y4C Unsupported Cisco Device on Prime Infrastructure 3.6
Have you got the latest device packs installed as these switches are very new , it may need the latest pack to see them ....
Beginner
Hello
NO Device pack available for now on prime infra 3.6.
From the matrix compability prime infra 3.6 support Catalyst 9500.
I will open a TAC case and let you know.
VIP Mentor
Yes please let me know if you find out i have 9410s / 9300s all coming online soon will need to be added to PI ill guess we will probably have same issue
Beginner
Yes I'll let you know.
Hall of Fame Guru
Raise a TAC Case.
Beginner
after opening a TAC case it appears that the SYS OID of Catalyst 9500-48Y4C for Virtual StackWise is unsupported by Cisco Prime Infrastructure 3.6.
It seems that the SYS OID of C9500-48Y4C is different when virtual StackWise 2 x Catalyst 9500...
Hall of Fame Guru
Go back to TAC and ask them to knock up a device pack code to support the OID.
Beginner
I already asked them. The TAC answer :
Thanks for providing the requested information. I was able to confirm that support for this particular model SYSOID will only be available in DNAC. Regarding Prime Infrastructure integration, the below enhancement has been submitted to the Prime Infrastructure developers. However, there curently is no plan to have this model SYSOID supported in the application. Please let me know if you have any additional/questions concerns with this SR. Thank you…
This SR was closed by the TAC...
Hall of Fame Guru
I'd escalate this with your Cisco AM/SE.
Beginner
This had already been done to SE who escalated to BU.
Content for Community-Ad
