05-23-2019 09:43 AM
I recently installed Cisco Prime Infrastructure 3.5 so as to manage catalyst 2k, 9200 and 9500 then upgrade to Prime Infrastructure 3.6 to support 9500 switches.
It appears that Catalyst 2k and Catalyst 9200 are managed correctly and 9500 is shown as "Unsupported Cisco Device".
The part number of the Catalyst 9500 is : C9500-48Y4C
The 9500 ICMP and SNMP reachability are OK.
From the Cisco Prime Infrastructure Device Supported document find here, it seems that this hardware is supported.
Does anyone hit this behaviour ? I don't find any bug document about it.
05-23-2019 11:26 PM
05-26-2019 06:51 AM - edited 05-26-2019 06:54 AM
Hello
NO Device pack available for now on prime infra 3.6.
From the matrix compability prime infra 3.6 support Catalyst 9500.
I will open a TAC case and let you know.
05-27-2019 12:37 AM
05-27-2019 06:48 AM
Yes I'll let you know.
05-26-2019 05:27 AM
07-01-2019 02:14 AM
07-01-2019 04:57 AM
@ssambourg wrote:
after opening a TAC case it appears that the SYS OID of Catalyst 9500-48Y4C for Virtual StackWise is unsupported by Cisco Prime Infrastructure 3.6.
Go back to TAC and ask them to knock up a device pack code to support the OID.
07-01-2019 05:13 AM
07-01-2019 11:49 PM
07-02-2019 08:41 AM
This had already been done to SE who escalated to BU.
08-07-2019 11:16 PM
Hello ssambourg,
we have the problem also with C9500-48Y4C (unsupported device). Do you got in meantime some information how we can fix this Issue?
Thanks a lot.
Martin
08-08-2019 05:26 AM
- This has already been replied to in the thread :
Thanks for providing the requested information. I was able to confirm that support for this particular model SYSOID will only be available in DNAC. Regarding Prime Infrastructure integration, the below enhancement has been submitted to the Prime Infrastructure developers. However, there curently is no plan to have this model SYSOID supported in the application. Please let me know if you have any additional/questions concerns with this SR. Thank you…
08-28-2019 01:22 AM
You are right ! Just one important word in : there curently is no plan
May be this plan will exist !
08-28-2019 02:08 AM
