CAB-Stack-7M Cables
shakeeb_shakeeb
Have any one used a Cab-Stack-7M cable to connect two 3750 series Switches.
I need to connect two switches with the stack cable but the distance between 2 switches are about 20feet. I saw a CAB-STACK-7M cable available on
http://www.connectzone.com/cab-stack-7m.html.
But before buying this cable I like to know if anyone have already used this cable. And caused any problem after using the 7M stack cables.
Thanks in advance ..
Marvin Rhoads
I've never used them and I'd be very hesitant to endorse such a cable as the Cisco original cables are only offered in 50 cm, 1m and 3m lengths. If you had any issues, you would not be running a supported configuration.
