Call Manager & IP Phones in LMS 4.1 topology
Hi Guys,
I have installed LMS 4.1 and discover all the devices (router/switches) but i want to show IP Phone on the LMS. I am unable to discover call manager in LMS 4.1 topology.
In Call Manager 8.6 in Cisco Serviceability under snmp setting i have enable the read community string and check snmp, MIB service are running.
AM i using the correct proecdure. How can i get the Call Manager on LMS server so that i can see IP phones on LMS topology.
8.6 is installed on VM Ware.
Looking for your reply.
Need urgent Help
Thanks in advance.
Looking for replies in the above issue..Have to solve ASAP.
Just replied on :
https://supportforums.cisco.com/thread/2162934
Along with SNMP process, the Call Manager process should also be running.
You can check if the snmp is reachable from LMS server, do a snmpwalk on CUCM either from Device Centre or you can do is from NMSROOT/objects/jt/bin/snmpwalk.
Syntax:
NMSROOT/Objects/jt/bin>snmpwalk -v -c
Example:
NMSROOT/Objects/jt/bin>snmpwalk -v 2c -c public 10.10.10.1 .1.3.6.1.2.1.1
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Zaher Juha
Beginner
Beginner
Facing the same problem
with LMS 4.2.2
have you solve it fazal from tera
this is zaher
Hi Zaher,
you have to add Call Manager server in the the LMS  and add the SNMP details for LMS server details in the call manager, as far as i remember its in serviceability. Check once.
You will get the result as shown in attached images.
