10-20-2011 06:55 AM
I'm trying to manage some call managers in our network. They are being discovered by CS, DFM and RME successfully however not in Campus Manager.
Read only SNMP is configured in all call managers. Anyone experienced this problem? Please share the solution.
Thank you
10-20-2011 10:30 AM
When you say "not discovered" do you mean it is not put on the layer2 topology map?
Try turning on CDP on the callmanagers
Cheers,
Michel
10-20-2011 11:04 AM
Hi Michel,
The call managers are not showing in the Campus Manager and yes they are not also showing in the layer 2 topology map.
I'll try turning on the CDP and will let you know.
10-20-2011 11:40 PM
Another service to check if the callmanager SNMP service. Otherwise the CCM is seen as just a host.
Cheers,
Michel
