Callmanager MIB and OID
rhegde
Is there a way a I can find more details about CISCO-CCM-MIB and its OIDs ? I am in a mid of uploading the CISCO-CCM-MIB  to Network Management App and select appropriate OIDs.. Can some one point me to a good document or link for monitoring the alarms and critical events on the Cisco Callmanager 7  cluster using SNMP MIBs ?
ccarring
The supported mibs for CallManager should be located on a page under the support lists here:
http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
And for MIB detail information, you can hit http://www.cisco.com/go/mibs and navigate to find the CISCO-CCM-MIB, or alternatively directly to where our mibs are available via ftp:
ftp://ftp.cisco.com/pub/mibs/v2/
IvanGO
Hi ccarring, i tried to download, but ask for user
thx
        - For FTP download , use your cisco id (CCO) and credentials
 M.
IvanGO
thanks for the answer! my issue was the ftp software to downloaded, just change it and done.
regards
