10-01-2005 04:50 AM
I recently upgraded from lms 2.2 to lms 2.5. The program is running on a windows 2000 server w/sp.4.
When I look at the following:
-->Campus Manager --> Administration --Current Status:
-->Operation: Device Discovery
-->Last Completion Time: Device Discovery Timestamp
Information is not available.
Probable cause:
You have not performed Device Discovery.
Results: 0 Devices
Status: Running
Action: Start Device Discovery
If I attempt to start a Device Discovery, I get a Warning that Device is already in progress! I finished the upgrade 2 days ago and the Device Discovery has been running ever since. Does anybody have any ideas why this hasn't completed yet? TIA
10-27-2005 12:13 AM
re-install SP2 patch for campus.
10-27-2005 07:29 AM
I applied both suggestions...no change...Thanks.
10-28-2005 01:17 PM
ok, then :
- save your campus topology map(campus\etc\users)
- uninstall campus manager
- reinstall campus manager and after sp2
10-29-2005 09:22 AM
I dont suppose you have authentication on the CiscoWorks installation to use ACS do you? Weve been using LMS 2.5 with ACS 3.3.2 and have the same problem unless we just use local logins and remove ACS authentication from the ciscoworks box.
**Im aware these two releases dont officialy work together and am waiting on the next IDU.
Try removing authentication to ACS if you have it configured and try then.
Nick
