campus manager
maged
serial links on the routers are seen as different routers in the campus manager . is there any way to solve this problem
umedryk
Level 5
Level 5
As far as I know, you cannot change the way the campus manager detects the serial link. But not sure what is the problem faced due to this.
Are you saying that if a router has 8 serial links, it is discovered and put into CM as 8 seperate devices?
Or are devices with multiple serial links randomely identified with different interfaces (i.e., router one is identified by ip on serial 0, router two is identified by ip on serial 3, etc)?
