11-23-2005 07:39 AM
LMS 2.5 (running CS 3.0) and QPM (running CS 2.2) are each installed on different servers (Windows).
We want to import the LMS devices in QPM via "Import from csv file". Is this still possible? Unfortunately this failed with the following message: "The file format is incorrect...." Import from RME also failed. Any suggestion?
11-23-2005 11:47 AM
You will have to convert the csv file to the old format.
Basically, LMS 2.5 uses csv version 3, and QPM does not understand it.
11-30-2005 07:25 AM
Still doesn't work.
It looks like bug CSCeg90304 which is resolved in QPM 3.2.2 patch.
We will give it a try.
