Can't assign static ip to pppoe subscriber
mrwisthis
Beginner
Beginner
Hello all,
I have ASR1004 and a freeradius server. I try to assign static ip address to subscriber. I tryed "Framed-IP-Address" and Cisco-avpair "ip:addr=x.x.x.x", but seems Cisco is ignoring them. I also tryed configuring seppared ip pools for each subscriber with only one ip address and set avpair to "ip:addr-pool=xxx", but subscriber gets always ip from the first pool in list.
Here is  my ASR1004 config:
version 17.5
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ASR1004
boot-start-marker
boot system flash bootflash:asr1000rpx86-universalk9.17.05.01a.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 9 xxxxxxxxxxxxxxxxxx
aaa new-model
aaa group server radius Opteron
server-private xxx.xxx.xxx.2 key 7 xxxxxxxxxxxxxxxxxxx
aaa authentication login default local
aaa authentication ppp PPPoE_LIST group Opteron
aaa authorization network PPPoE_LIST group Opteron
aaa accounting send stop-record authentication failure
aaa accounting delay-start
aaa accounting session-duration ntp-adjusted
aaa accounting nested
aaa accounting update periodic 1
aaa accounting exec default
action-type start-stop
group radius
aaa accounting network default start-stop group Opteron
aaa nas port extended
aaa session-id common
aaa policy interface-config allow-subinterface
transport-map type persistent webui webhandler
server
transport-map type persistent ssh sshhandler
rsa keypair-name ssh-key
transport interface GigabitEthernet0
connection wait allow interruptible
transport-map type console ssh_con
clock timezone EET 2 0
clock summer-time EEET recurring last Sun Mar 0:00 last Sun Oct 0:00
ip nbar http-services
ip name-server xxx.xxx.xxx.xxx
ip domain name xxxxx.xxx
ip dhcp relay information option
ip dhcp relay information trust-all
ip dhcp excluded-address xxx.xxx.160.1
ip dhcp excluded-address xxx.xxx.161.1 xxx.xxx.161.10
ip dhcp excluded-address xxx.xxx.160.201 xxx.xxx.160.254
ip dhcp excluded-address xxx.xxx.162.1
ip dhcp pool 160
network xxx.xxx.160.0 255.255.255.0
network xxx.xxx.161.0 255.255.255.0 secondary
default-router xxx.xxx.160.1
dns-server xxx.xxx.xxx.xxx
remember
login block-for 100 attempts 15 within 100
login delay 10
login quiet-mode access-class myacl
login on-success log
subscriber templating
subscriber authorization enable
virtual-profile if-needed
virtual-profile virtual-template 1
multilink virtual-template 1
vpdn enable
no virtual-template snmp
license udi pid ASR1004 sn xxxxxxxxxx
license accept end user agreement
license boot level advipservices
memory free low-watermark processor 417477
et-analytics
diagnostic bootup level minimal
redundancy
mode none
class-map match-all dscp-inet
match dscp af11
class-map match-all xxxxxxxx
match ip precedence 1
policy-map test-client
class dscp-inet
police cir 1048500
conform-action transmit
exceed-action drop
class dscp-bg
police cir 2097000
exceed-action drop
policy-map xxxxxxxxxxx_pm
class xxxxxxxxx
police cir 10000000
conform-action set-dscp-transmit af11
exceed-action set-dscp-transmit af11
bba-group pppoe global
virtual-template 1
vendor-tag circuit-id service
sessions per-mac limit 1
sessions auto cleanup
interface Null0
no ip unreachables
no ipv6 unreachables
interface Loopback0
no ip address
no ip proxy-arp
interface Loopback1
no ip address
interface TenGigabitEthernet1/1/0
no ip address
no ip proxy-arp
interface TenGigabitEthernet1/2/0
no ip address
interface TenGigabitEthernet1/2/0.10
encapsulation dot1Q 10
ip address xxx.xxx.x16.8 255.255.255.240
interface TenGigabitEthernet1/2/0.692
encapsulation dot1Q 692
ip address xxx.xxx.xxx.27 255.255.255.248
interface TenGigabitEthernet1/3/0
no ip address
interface TenGigabitEthernet1/3/0.137
encapsulation dot1Q 137
ip address xxx.xxx.160.1 255.255.255.0
interface TenGigabitEthernet1/3/0.138
encapsulation dot1Q 138
ip address xxx.xxx.162.1 255.255.255.0
pppoe enable group global
interface TenGigabitEthernet1/3/0.140
encapsulation dot1Q 140
ip address xxx.xxx.169.1 255.255.255.0
vrf forwarding Mgmt-intf
ip address 192.168.99.9 255.255.255.0
negotiation auto
interface Virtual-Template1
ip unnumbered TenGigabitEthernet1/3/0.138
no logging event link-status
peer default ip address pool Subs2 Subs3 Subs4 Subs5
keepalive 60
ppp mtu adaptive
ppp authentication chap PPPoE_LIST
router ospf 1
router-id xxx.xxx.xxx.xxx
area 0 authentication
passive-interface default
network xxx.xxx.xxx.xxx 0.0.0.7 area 0
network xxx.xxx.xxx.xxx 0.0.0.15 area 0
distribute-list 10 in
router rip
version 2
neighbor xxx.xxx.xxx.xxx
no auto-summary
router bgp 21230
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor xxx.xxx.xxx.xxx remote-as 41313
address-family ipv4
redistribute connected route-map redis-connected-to-nvt
redistribute static route-map redis-static-to-nvt
neighbor xxx.xxx.xxx.xxx activate
neighbor xxx.xxx.xxx.xxx soft-reconfiguration inbound
neighbor xxx.xxx.xxx.xxx prefix-list peer_export out
exit-address-family
iox
ip local pool Subs2 xxx.xxx.162.2
ip local pool Subs3 xxx.xxx.162.3
ip local pool Subs4 xxx.xxx.162.4
ip local pool Subs5 xxx.xxx.162.5 group Opteron
ip http server
ip http access-class ipv4 20
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip bgp-community new-format
ip as-path access-list 100 permit ^$
ip as-path access-list 100 deny .*
ip tftp source-interface GigabitEthernet0
ip route xxx.xxx.161.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.162.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.163.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.164.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.165.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.166.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.167.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.168.0 255.255.255.0 Null0 tag 100
ip route xxx.xxx.169.0 255.255.255.0 Null0 tag 100
ip ssh version 2
ip prefix-list peer_export seq 5 permit xxx.xxx.160.0/24
ip prefix-list peer_export seq 10 permit xxx.xxx.161.0/24
ip prefix-list peer_export seq 15 permit xxx.xxx.162.0/24
ip prefix-list peer_export seq 20 permit xxx.xxx.163.0/24
ip prefix-list peer_export seq 25 permit xxx.xxx.164.0/24
ip prefix-list peer_export seq 30 permit xxx.xxx.165.0/24
ip prefix-list peer_export seq 35 permit xxx.xxx.166.0/24
ip prefix-list peer_export seq 40 permit xxx.xxx.167.0/24
ip prefix-list peer_export seq 45 permit xxx.xxx.168.0/24
ip prefix-list peer_export seq 50 permit xxx.xxx.169.0/24
ip radius source-interface TenGigabitEthernet1/2/0.10
ip access-list standard 10
1 permit xxx.xxx.xxx.0 0.0.0.15
ip access-list standard 20
10 permit xxx.xxx.xxx.0 0.0.0.255
20 permit xxx.xxx.xxx.0 0.0.0.255
30 permit xxx.xxx.160.0 0.0.0.255
40 permit xxx.xxx.161.0 0.0.0.255
50 permit xxx.xxx.162.0 0.0.0.255
60 permit xxx.xxx.163.0 0.0.0.255
70 permit xxx.xxx.164.0 0.0.0.255
80 permit xxx.xxx.165.0 0.0.0.255
90 permit xxx.xxx.166.0 0.0.0.255
100 permit xxx.xxx.167.0 0.0.0.255
110 permit xxx.xxx.168.0 0.0.0.255
120 permit xxx.xxx.169.0 0.0.0.255
route-map to-nvt-out permit 10
match community 21230:10002
route-map redis-static-to-nvt permit 10
match tag 100
set local-preference 120
set origin igp
set community 21230:10002
route-map redis-connected-to-nvt permit 10
match ip address prefix-list peer_export
set origin igp
route-map To-xxxxxx permit 10
snmp-server manager
radius-server attribute 44 extend-with-addr
radius-server attribute 218 mandatory
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req
radius-server attribute 55 include-in-acct-req
radius-server attribute 61 extended
radius-server attribute 4 xxx.xxx.xxx.2
radius-server attribute 31 mac format ietf
radius-server attribute 31 send nas-port-detail mac-only
radius-server configure-nas
no radius-server vsa send accounting
no radius-server vsa send authentication
radius server Opteron
address ipv4 xxx.xxx.xxx.2 auth-port 1812 acct-port 1813
timeout 1000
retransmit 6
key 7 00091D03100859571928564708171F
control-plane
call admission new-model
call admission limit 1000
call admission cpu-limit 80
call admission pppoe 10 1
line con 0
stopbits 1
line aux 0
access-class myacl in
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxxxxx
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
0 Replies 0
Recognize Your Peers
