Highlighted
Can't figure out what I'm doing wrong.
Hi all, I need help.  I attached the packet tracer that I am using to model a network we are building in our student-lab. Everything from PC's on left through the egress of 1st router seems fine, can ping all the way through the router.  G0/0/0 side is /25, g0/0/1 side to IDF is /26.  Again, I can ping through the router, but everything dies at the switch and I can't figure out what I'm doing.  I need to have multiple vlans and will eventually trunk into World router (labeled).  I've tried switchport access with multiple vlans, which I thought should work, but I can't even ping the switch vlan addresses that each router is directly attached to.
Anything labeled Capital is on 192.168.50.xxx /25 and /26 , 2nd City is 172.16.50.xxx /25 and /26.  I guess I can't attach the packet tracer, below is notepad config lines from each router to switch.  Thank you!!
*Capital Router Config*
en
config t
hostname ChrisCap-RTR
enable secret GoGreen123!
no ip domain-lookup
banner motd "GoGreen or GoHome"
line console 0
logging synchronous
password GoGreen123!
login
line vty 0 15
login
transport input telnet
exit
int g0/0/1
description IDF cnx
ip address 192.168.50.126 255.255.255.192
no shut
int g0/0/0
description SERVER cnx
ip address 192.168.50.129 255.255.255.128
no shut
exit
router ospf 1
network 192.168.50.128 0.0.0.127 area 0
network 192.168.50.64 0.0.0.63 area 0
network 0.0.0.0 0.0.0.0 area 0
exit
exit
copy run start
_________________________________________________________________________
*Second City Router Config*
en
config t
hostname Chris2-RTR
no ip domain-lookup
line console 0
logging synchronous
login
line vty 0 15
login
exit
int g0/0/1
description IDF cnx
ip address 172.16.50.126 255.255.255.192
no shut
int g0/0/0
ip address 172.16.50.129 255.255.255.128
no shut
exit
router ospf 1
network 172.16.50.128 0.0.0.127 area 0
network 172.16.50.64 0.0.0.63 area 0
exit
exit
copy run start
*IDF Server Side*
en
config t
no ip domain-lookup
hostname ChrisCap-SW
line console 0
logging synchronous
login
exit
line vty 0 15
login
exit
vlan 10
vlan 20
int vlan 10
ip address 192.168.50.100 255.255.255.192
no shut
int vlan 20
ip address 172.16.50.100 255.255.255.192
no shut
int fa0/1
switchport mode access
switchport access vlan 10
no shut
int fa 0/2
switchport access vlan 20
no shut
exit
exit
copy run start
1 ACCEPTED SOLUTION
Re: Can't figure out what I'm doing wrong.
Thanks for the reply.  It seems to have been a glitch in Packet Tracer, I simply removed the switch and inserted a new one with the same configurations and it works fine.  Thanks again.
2 REPLIES 2
Engager
Hi cdoering.cna@gmail.com ,
Could you compress your exercise (with winzip, for example) and attach it to review the settings?
Content for Community-Ad
