04-15-2020 08:33 AM - edited 04-15-2020 08:36 AM
hello
in cisco IOS i was used "Configuration Change Notification and Logging"
but in cisco sw-nexuis i can't fine the commend
SW-nex3000(config)# archive SW-nex3000(config-archive)# log config ^ % Invalid command at '^' marker. SW-nex3000(config-archive)# notify syslog ^ % Invalid command at '^' marker. SW-nex3000(config-archive)#
i need to send any Configuration Change Notification to syslog server
Solved! Go to Solution.
04-15-2020 08:42 AM
- Check of the solving-reply of this thread can apply to your case :
M.
04-15-2020 08:42 AM
M.
