05-25-2022 01:38 AM
05-25-2022 02:03 AM
It supports cdp and lldp. Make sure the switch have cdp and or LLDP enable as well. If not, enable it.
05-25-2022 02:54 AM
My Vodafone router does not offer CDP or LLDP as I can see.
05-25-2022 02:57 AM
Usually devices with PoE function have some negociation protocol like CDP or LLDP. Which Vodafone device is this? and are you trying to get power from this device? Or are you using Power Injector instead?
05-25-2022 05:34 AM
I thought all routers can do PoE out of the box but 8865 does not react.
Do I need a crossed cable or something like that? The Vodafone router is connected to a cable network via cable connection.
05-25-2022 05:49 AM
PoE is a feature, so, either your device supports or not. Which is the router model, let´s check on the vendor docs.
05-25-2022 02:08 AM
What is the exact model is the switch or power injector?
05-25-2022 02:57 AM
It is a Vodafone WiFi Certified 6 Router I'm using.
05-25-2022 04:01 AM
DSL router usually do not support PoE.
To get this phone to work, a power injector or a power brick is needed.
