04-30-2021 10:53 AM
Hello.
I make many sensors for PRTG.
I want to see EIGRP neighbours status and make single sensor with multiple channels (for PRTG free edition
Sensor get all EIGRP neighbours in all AS and save it to JSON file.
After this, You can stop sensor, edit JSON and add names.
Then You need delete and add sensor again, because PRTG do not allow delete old channels.
Also I make BGP sensor but I will make documentation in near future.
You can download and use it for free.
https://github.com/OlegPowerC/psPowerEIGRP
Also I send it to PRTG Script world but today
04-30-2021 10:57 AM
05-03-2021 07:22 AM
Fixed error with neighbor loss.
Now it work correct
05-04-2021 04:24 AM
Fixed UPTIME error
05-04-2021 06:28 AM
Also new BGP sensor:
https://github.com/OlegPowerC/psPowerBGP
05-05-2021 12:16 AM
Now at scrip world:
02-16-2024 01:23 PM
When I try to use your script I am getting this error:
This version of %1 is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher. (0xD8)
