05-19-2022 08:56 AM
Hi 200-301
I started my course ccna 200-301
The first issue i get, is : i cant ping another pc with diferente Ip conected to the same router.
see the image attahed
Please assist
05-19-2022 09:07 AM
your image is not attached. check if your router have ip routing command in global configuration mode. also make sure PC firewalls are disabled
05-20-2022 12:07 AM
in case this is a Packet Tracer project, post your zipped project (.pkt) file...
05-20-2022 01:25 AM
Thanks all
i add DG and works
