Catalyst 2960X / SNMP / ARP rate
sharlino
Is it possible to get an actual ARP rate (PPS) per interface via SNMP ?
RBeugnies
I believe you can only have an average 5 minute PPS, for example, OID:1.3.6.1.4.1.9.2.2.1.1.7
I would suggest looking at the SNMP Object Navigator on Cisco's website, the MIB file will provide a description of each OID.
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.2.2.1.1.7&translate=Translate&submitValue=SUBMIT&submitClicked=true
Thanks! Unfortunately, .1.3.6.1.4.1.9.2.2.1.1.7 does not provide an ARP rate.
balaji.bandi
Not that i am aware of it is available. instead you can EEM Script to send show command to send to logs and make report based on that.
BB
Thanks for suggestion!
