Catalyst 500 series
Ahmed Malik
hi,
   i have a question regarding cisco 500 series switches and it is that if we want to shut down this switch remotely then is it possible or it has to be done manually by going to the switch location and disconnecting the power supply because i dont see a power off or shut down option if it is accessed remotely like from a pc.
regards
Ahmed
Michel Hegeraat
Level 7
Level 7
I don't think many devices are meant to be shutdown. As soon as there is power they run. That's what they are made for.
What do you wish to acomplish with the shutdown?
Cheers,
Michel
