03-20-2019 05:46 AM
My issue, I think, is I cannot see interface Fo1/0/1 in any netflow server (Managengine Netflow, Extrahop Netflow). I can only see a Null interface only on interface fo1/0/1, I can add other interfaces and they will show up in the Netflow server choice of interfaces to monitor. One more thing I only see inbound and not outbound traffic. Please see my configuration below not sure if correct:
Cisco Catalyst C9500-32QC
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji]
flow record record-ingress
description IPv4 ingress
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destination-port
match ipv4 tos
match interface input
match flow direction
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
flow record record-egress
description IPv4 egress
match ipv4 protocol
match ipv4 tos
match interface output
collect interface input
flow exporter FlowExporter
description NETFLOW Export to Netflow
destination xx.xx.xx.xx
source Loopback0
transport udp 9996
template data timeout 60
flow monitor fm-input
description IPv4 ingress exports
cache timeout active 60
flow monitor fm-output
description IPv4 egress exports
interface FortyGigabitEthernet1/0/1
description Corp WAN
ip flow monitor fm-input input
ip flow monitor fm-output output
ip address xx.xx.xx.xx xx.xx.xx.xx
ip ospf message-digest-key 1 md5
ip ospf network point-to-point
ip ospf hello-interval 2
ip ospf cost 1
show flow monitor fm-input cache format table
Cache type: Normal (Platform cache)
Cache size: 10000
Current entries: 21928
Flows added: 292930320
Flows aged: 292908392
- Active timeout ( 60 secs) 22609577
- Inactive timeout ( 15 secs) 270298815
IPV4 SRC ADDR IPV4 DST ADDR TRNS SRC PORT TRNS DST PORT INTF INPUT FLOW DIRN IP TOS IP PROT intf output
172.xx.xxx.xx 172.xx.xx.xxx 6970 50487 Null Input 0x00 6 Null
172.xx.xxx.xx 172.xx.xx.xxx 2000 49154 Null Input 0x60 6 Null
sho flow monitor fm-output cache format table
Cache size: 10000
Current entries: 22494
Flows added: 4993240
Flows aged: 4970746
- Active timeout ( 60 secs) 645159
- Inactive timeout ( 15 secs) 4325587
IPV4 SRC ADDR IPV4 DST ADDR TRNS SRC PORT TRNS DST PORT INTF OUTPUT FLOW DIRN IP TOS IP PROT intf input
10.xx.xx.xx 10.xx.xx.xx 5044 49246 Null Output 0x00 6 Null
137.xx.xx.xx 10.x.xx.xx 0 0 Null Output 0x40 47 Null
03-20-2019 06:17 AM
As I continue to troubleshoot this issue I noticed that the ports that are not showing have something in common each port that I cannot get to show up as a netflow port are using the QSFP TO SFP10G ADAPTER with a 10 SFP in a native QSFP 40G port. The native forty gig QSFP ports show up in netflow. This is most likely my issue. Not sure if there is a fix for this issue but I'll put it out there for any advise.
