CCP display issue
charleswindon
I'm having an odd time with CCP.  When I start it up, it only displays in the top part of IE.  I tried it with Firefox as well and got the same results.  There seems to be no way to expand it out so I can work with it.  Has anyone seen this before?  I'm using Windows 7 64 bit with IE 10.  Java 7 release 25.
Any thoughts on what is causing this and how to get around it?  The software is also installed locally, and not on the router, which is a Cisco 2811.  SDM on the router works just fine, as does ASDM on my PIX515E.
Ivan Windon
Ivan Windon - CCENT
Marvin Rhoads
Yes, several folks have reported this very same issue on this forum.
They have reported success at remedying this issue with fixes posted here.
Marvin Rhoads
Thanks for the info.  I also found that be downgrading to IE9 it will resolve the issue.
Ivan Windon - CCENT
