CCP Express 3.3 and 2921 ISR
ghyacin
I have downloaded CCP Express from CISCO, copied it to the router, extracted the file to the flash, configured the router as shown below but I am not able to get the CCP Express page to load. I am able to login when I try connecting to the routers IP address and get this error message "ERR_CONTENT_LENGTH_MISMATCH" or blank screen depending on the browser. If I type exec after the IP address, after I have logged in, I get the basic exec and configure page or option.
sh run:
Current configuration : 3069 bytes
! No configuration change since last restart
version 15.2
hostname HS-MainRTR-01
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip domain name h.s.local
ip cef
crypto pki trustpoint TP-self-signed-288992550
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-288992550
 revocation-check none
 rsakeypair TP-self-signed-288992550
crypto pki certificate chain TP-self-signed-288992550
 certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383839 39323535 30301E17 0D313730 34303131 38333931
  305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 38393932
  35353030 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  F15E606F AECCE216 70D88639 8EBFDF2E D5192AB3 DCF2460C A013DEFD 216A25BE
  8F5FBB37 29C26DCC D5B20646 A9C287ED 734CCAF5 3EBEB913 7BCD17E3 9CCA9AE8
  AD6FFF37 CEB57BE6 0A46477A D59D72FB 9572CE27 A6E45ED8 1BCCC9E2 3D1E7EC1
  3F6EC93E 89BDADA7 D76931CE 311249AD F8E16EAA 8BD150D1 9435BDFD 37D76C41
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 1680142D 8321E01C 4344903D C2CE734A CECE9660 0E290230 1D060355
  1D0E0416 04142D83 21E01C43 44903DC2 CE734ACE CE96600E 2902300D 06092A86
  4886F70D 01010505 00038181 0076C5E5 092D1719 95AC6549 3871C68A FE0533C1
  61BABA5F FBCE0BD1 34307491 F63020F0 C9138253 1CF054E5 D177C178 494E8BB2
  0921284D 400E7084 2482B323 A43A18C8 F8E337B7 083F992F F2239AEF A875A38D
  D769F05B EA146F6C 9B1A0700 69E4383A B376800E C3CF8810 6D39C14B B0A55A41
  B307E65F 669A4F06 CA7E3DAB 43
        quit
license udi pid CISCO2921/K9 sn FTX1520AJAZ
vtp mode transparent
username "username" privilege 15 secret 5 $1$S/8h$e.Sjfe.G3d17tKx9oyTHC0
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.1.254 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
interface Serial0/1/0
 no ip address
 shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Your output indicates the router is running IOS 15.2(2). The device side CCP Express on it requires 15.2(4)M2 or higher.
5 Replies 5
Marvin Rhoads
What 15.4 image are you running? CCP 3.3 requires 15.2.4M2 or later.
Also, have you tried just running the PC-based CP version 2.8 and pointing it at your router? It's much more full featured.
Go to the following site:
https://software.cisco.com/download/release.html?mdfid=281795035&softwareid=282159854&release=3.3&relind=AVAILABLE&rellifecycle=&reltype=latest
and look under "All Releases > 2.8" for for:
cisco-config-pro-k9-pkg-2_8-en.zip
I have installed and tried using CCP 2.8 for the pc and I am getting a java certificate security error when I login, then the program crashes when I try to use it for the router, but it works fine all the way around for my 3750G switch.
sh ver:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 15-Nov-11 22:10 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System restarted at 20:19:56 UTC Wed Apr 5 2017
System image file is "flash0:c2900-universalk9-mz.SPA.152-2.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1520AJAZ
3 Gigabit Ethernet interfaces
2 Serial interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FTX1520AJAZ
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
I upgraded the image and CCP Express loaded right up, Thanks for all the help.
You're welcome. Thanks for letting us know the outcome and rating the answer.
