I have upgraded cisco NCS-5504 router . Router was successfully upgraded but all the line cards are not showing. In platform command type is unknown and state is SW_Inactive.Regards Salman
The content you are looking for has been archived. View related content below.
Hello. We're currently running Meraki, and there is an issue we found. As far as I know, MX failover is automatically activated when the WAN is disconnected. If WAN Loss reaches a certain threshold, can't you force failover to Unit 2? Thank you.
This started about last week; no changes have been made to any of the switches. We're a small business so not very many employees, but we're a TV station so we have multitudes of servers.Our Primary ISP is a 2gig by 2gig connection, same as our Secon...
My network endpoints use the IP addressed vlans on my core cisco layer three core switch as their gateway addresses. i.e.- vlan 11 endpoint address 192.168.11.3/24 with gateway 192.168.11.1/24 (vlan ip on core) and vlan 12 endpoint address 192.168.12...
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
how to get Original Equipment Manufacturers (OEMs)
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Hello all, I have inherited an infrastructure with several catalyst 9200 switches. A few of them are unreachable when using ssh from a terminal, such as a linux server or Powershell. The error message is this: Unable to negotiate with <IP ADDRESS> po...
I want to create an ACL on Cisco to prevent one network from communicating with others except for the internet. Can you help?
Having tried to register the MAC address on the website, the LED on the device is still flashing blue.
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
I cannot edit or duplicate template is Prime Infrastructure anymore.It started many month ago with Chrome.My Workaround was to use Firefox.But with the Update to Firefox 125 the same Issue is now happening here.I guess Chrome and Firefox disabled som...
Hello. I can't log on CSLU using cisco account, but I can log on other cisco web sites using same credentials. (license, download... etc) I also can pass test connection in CSLU. The strange thing is I can log on CSLU using my private cisco account. ...
Subject | Author | Posted |
04-23-2024 05:52 PM | ||
04-23-2024 12:20 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM |
User | Count |
4 | |
2 | |
2 | |
2 | |
1 |
