CDP Packet
sabrouch001
Please I would like to know the size and the composation of a CDP packet, and if the CDP make a lot of traffic on the network.
4 Accepted Solutions
DAVID NOONAN
Info on the CDP frame:
http://www.cisco.com/univercd/cc/td/doc/product/lan/trsrb/frames.htm#xtocid12
CDP traffic is layer-2 so it's generally confined to a single segment. CDP sends a multicast frame every 60 seconds (by default, it can be changed with the "cdp timer") so it shouldn't be much traffic.
Richard Burts
Sabri
From a capture I did the CDP packet is 194 bytes. It has a standard layer 2 header for 802.3 SNAP with a multicast MAC destination address. There is no layer 3 information in the frame. The payload is the CDP data.
No the CDP traffic does not make a lot of traffic on the network. It is a pretty small packet on the network, once every 60 seconds. Given the helpful information that CDP can generate I believe that it is well worth running CDP. And the load that it puts on the network is pretty insignificant.
Rick
Rick
Some (i.e., National Secuirty Agency: http://www.nsa.gov/snac/downloads_cisco.cfm?MenuID=scg10.3.1, reference paragraph 4.2.1, page 69) have argued that cdp can be considered a security risk as it potentially exposes information about your platform to untrusted sources.
I don't share that opinion, except for public-facing interfaces. In those instances only, I would advocate "no cdp" on the interface. Properly isolated (firewall, etc.) interfaces should use cdp for the utlility it adds - especially for networks using CiscoWorks as an element manager - not having cdp enabled disables much of the Campus Manager tools' functionality (e.g., the ANI discovery process).
Attached is a text printout of a CDP packet captured in Ethereal. I captured this from a 3548 switch in my lab.
5 Replies 5
DAVID NOONAN
Richard Burts
Sabri
Rick
Rick
thank you for your help
