I have used the GUI to change the location of the /devfiles directory to the /opt directory because I have run out of inodes on the /var directory. I'm wondering if the old directories under /var will be removed once the GUI completes the change? Will I need to go in and manually remove the /devfiles directory after all files have been moved. Also, do all directories get moved or just the ones that are current, meaning, there may be all dirs out there if a reinit was ever done on the rme database?
LMS 3.1, RME 4.2.0 on Solaris 9
thanks. Marcie
