Changing address of Cisco Prime LAN 4.x
ronald.nutter
Beginner
Beginner
Would like to ask for a little help on changing the ip address of a Cisco Prime LAN server I am working with.  Another server was previously using the ip address of what has been assigned to Cisco Prime Lan.  Figured it would be easier to change the IP address of Prime than the reinstallation that would be required with the other server.  I changed the ip address of Prime and cant get into the web interface.  I can SSH to the server.
Is there something else that I need to change ?  I have looked on the forums and other places and havent found a fix to the problem.
Tried to change the ip address back.  Can SSH to the original address but web interface doesnt come up.
Would hope to avoid reinstallin Prime and loosing my existing configuration.
Ron
Marvin Rhoads
VIP Community Legend VIP Community Legend
Ron,
It should work once you restart the server. You don't have to reboot - just restart LMS. This adressed in the Admin Guide FAQ here.
Stop/start on windows:
net stop crmdmgtd (takes 2-3 minutes to stop processes)
net start crmdmgtd (can take up to 20 minutes to completely start, silent status unless you know how to run pdshow or check lock directory)
On soft appliance:
application stop LMS
application start LMS (can check progress with "show application status LMS")
Marvin Rhoads
Ron,
On soft appliance:
