Changing from RV110W to RV160W
rgwedgwood
We have been using an RV110 for a number of years with a Virgin leased line without issue.  Recently we need to keep powering down the device and rebooting to restablish Internet connection so decided to upgrade to the newer RV160.  However, the User Interface seems a lot more complex and I'm having trouble setting it up and getting it to work.
One of the settings I cannot find anywhere on the RV160 is the selection of operating mode found under the Routing tab.  One the 110W we have 'Gateway' selected as the operating mode - but cannot find this anywhere on the RV160 which I suspect may be the route of the issues I'm experiencing.
Any ideas?
rgwedgwood
Managed to get this sorted!
balaji.bandi
If you looking to setup WAN and default gateway available in WAN Settings / IPv4 Settings.
if you want to routing, you can do Routing - static routing towards your WAN Interface ?
is this what you looking or give us 110W screenshot to understand better.
BB
Many thanks for your response. Screenshot as requested.
[image: image.png]
rgwedgwood
