Changing vlan on interface with Cisco Prime Infrastructure 2.0
Dear all,
I want to create a template for replacing vlan on some interface on lot of switch.
i ve done this one :
#foreach ($interfacename in $interfaces)
interface $interfacename
           #if ($Vlanid == $Vlanidold)
                                  no switchport access vlan $Vlanidold
                                  switchport access vlan $VlanidNew
           #end
#end
that doesn t work..:-(
the test for the vlanid doesn t work.
Could you give me some help
Thanks by advance
JAMES THOMAS
Beginner
Beginner
Did you ever get this working?
JAMES THOMAS
Beginner
Beginner
it still not works.. i stopped to search and i used notepad++ extract the conf, change the conf and deploy the conf ...switch by switch
Still no answer for this?
Recognize Your Peers
