10-04-2017 02:11 AM - edited 03-01-2019 06:10 PM
Hy Everybody.
I have a Cisco router 1800 and i would like use FailOver.
I have my Configuration whch works but i still have a little detail to solve.
service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname routeur-cisco1811 ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret 5 XXXXXXX/ ! aaa new-model ! ! aaa authentication login default local ! ! aaa session-id common ! ! dot11 syslog ip source-route ! ! ip dhcp excluded-address 192.168.3.1 ip dhcp excluded-address 192.168.3.2 192.168.3.99 ip dhcp excluded-address 192.168.3.200 192.168.3.252 ip dhcp excluded-address 192.168.3.254 ip dhcp excluded-address 192.168.3.253 ! ip dhcp pool CASA_LAN network 192.168.3.0 255.255.255.0 dns-server 8.8.8.8 default-router 192.168.3.254 ! ! ip cef no ip domain lookup ip domain name domoticity.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef ! multilink bundle-name authenticated ! ! ! username domoticity privilege 15 secret 5 XXXXXXX ! ! ! archive log config hidekeys ! ! ip ssh time-out 60 ip ssh logging events ip ssh version 2 ! track 1 ip sla 1 reachability ! track 2 ip sla 2 reachability ! track 3 list boolean and object 1 object 2 ! ! ! interface FastEthernet0 description Acces principal FTTH ip address 192.168.1.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 description Acces secour 3/4G ip address 10.0.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet2 switchport access vlan 2 ! interface FastEthernet3 switchport access vlan 3 ! interface FastEthernet4 switchport access vlan 4 ! interface FastEthernet5 switchport access vlan 5 ! interface FastEthernet6 switchport access vlan 6 ! interface FastEthernet7 switchport access vlan 7 ! interface FastEthernet8 switchport access vlan 8 ! interface FastEthernet9 switchport access vlan 9 ! interface Vlan1 no ip address ! interface Vlan2 description domoticity ip address 192.168.2.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan3 description casa ip address 192.168.3.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan4 description stockage ip address 192.168.4.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan5 description domotique et cameras ip address 192.168.5.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan6 description sentinelle ip address 192.168.6.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan7 description Monotoring surveillance generale ip address 10.1.1.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan8 description Orange travail ip address 192.168.8.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan9 description Serveurs multimedia ip address 192.168.9.254 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 3 ip route 0.0.0.0 0.0.0.0 10.0.0.1 10 ip route 90.116.11.243 255.255.255.255 192.168.1.1 no ip http server no ip http secure-server ! ! ip nat inside source route-map BACKUP_ISP interface FastEthernet1 overload ip nat inside source route-map MAIN_ISP interface FastEthernet0 overload ! ip sla 1 icmp-echo 192.168.1.1 source-ip 192.168.1.254 ip sla schedule 1 life forever start-time now ip sla 2 icmp-echo 90.116.11.243 source-ip 192.168.1.254 ip sla schedule 2 life forever start-time now access-list 100 permit ip 192.168.2.0 0.0.0.255 any access-list 100 permit ip 192.168.3.0 0.0.0.255 any access-list 100 permit ip 192.168.4.0 0.0.0.255 any access-list 100 permit ip 192.168.5.0 0.0.0.255 any access-list 100 permit ip 192.168.6.0 0.0.0.255 any access-list 100 permit ip 192.168.8.0 0.0.0.255 any access-list 100 permit ip 192.168.9.0 0.0.0.255 any access-list 100 permit ip 10.1.1.0 0.0.0.255 any ! ! ! ! route-map BACKUP_ISP permit 10 match ip address 100 match interface FastEthernet1 ! route-map MAIN_ISP permit 10 match ip address 100 match interface FastEthernet0 ! ! ! control-plane ! ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! event manager applet CLEAR_NAT_DOWN event track 3 state down action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" event manager applet CLEAR_NAT_UP event track 3 state up action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" ! end
So i have a Fiber Box where is connected the wan1 (FastEthernet0) and a 3gBox where is connected the wan2 (FastEthernet1).
When disconnect the wan 1,it balances to wan2. And when i connect again the wan 1,it balances to wan1.
In my configuration, in red you have my ISP ip.
My provider changes my ISP ip sometimes and every internet Cut.
I have a FQDNs at noip.
a very nice person from the forum :), tells me that i can't remplace my ISP ip by my FQDNS and it's better to turn to a EEEM script.
I know only do bash and php script.But no EEEm Scripts.
Some can help me please :)
Solved! Go to Solution.
12-12-2017 03:46 AM
You need to post the debug output when you execute the policy using the track event detector. The debug output will appear on any monitored line.
12-12-2017 03:50 AM
Si When i dit thé débug i have thé line « My ip XXXXX » where Xxxxx is my ip
12-31-2017 08:45 AM
Hy,
I need you again :)
so when i put
event none
instead
event track 2 state down
and launch the script manually it works.
I don't understand what is wrong
12-31-2017 01:12 PM
I have been asking you for the debug output, but you do not provide it. Without that I cannot say why the script does not work when you use the track event detector.
12-31-2017 02:40 PM
01-02-2018 06:29 AM
Enable "debug event manager action cli" and trigger the policy via the tracked object. Post the output from either a monitored line or the "show logg".
01-14-2018 07:50 AM
Hy,
Cisco is Magic lol
I haven't modified my script and now everything works.
When i unplug the wan0 or cut the fiber connexion,
it balances into 3g connexion.
When i plug again the wan0 or reload the fiber connexion,
my Cisco router come back to the fiber connexion.
Thank you a lot. :)
