11-24-2010 09:17 AM
Hi all,
I am facing a problem in upgradation Ios of router. I have uploaded new image but still it is booting from old IOS.
old ios :c2800nm-advipservicesk9-mz.124-12.bin
new IOS: c2800nm-advipservicesk9-mz.124-25d.bin
config#boot system flash:\c2800nm-advipservicesk9-mz.124-25d.bin
I have check other IOS version as well but still showing me same.
I would highly appreciate if someone can give me some time to solve this issue.
Solved! Go to Solution.
11-29-2010 05:46 AM
Dear I know this command, plz go through to get to know what is going on..
11-29-2010 06:37 AM
Manish,
can you please issue the following commands and post the output:
verify flash:c2800nm-advipservicesk9-mz.124-25d.bin
verify system:running-config
verify nvram:startup-config
show startup | incl boot
(you posted the output of the running config not the startup ...)
11-29-2010 06:56 AM
Hi Martin,
thanks a lot for time. below is the commands output:
#verify flash:c2800nm-advipservicesk9-mz.150-1.M4.bin
%Filesystem does not support verify operations
Verifying file integrity of flash:c2800nm-advipservicesk9-mz.150-1.M4.bin.................................................................................................................................................................................................Done!
Embedded Hash MD5 : C632A4EEBEC0EE7611C17DB31C4DAF1F
Computed Hash MD5 : C632A4EEBEC0EE7611C17DB31C4DAF1F
CCO Hash MD5 : 08899810F688F12725A852C270FF097A
#verify system:running-config
#verify nvram:startup-config
#show startup-config | in boot
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.150-1.M4.bin
boot system flash:c2800nm-advipservicesk9-mz.124-12.bin
boot-end-marker
11-29-2010 07:47 AM
can you please post the output of
show version
11-29-2010 07:50 AM
I#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 17-Nov-06 12:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
device uptime is 2 days, 21 hours, 55 minutes
System returned to ROM by reload at 17:51:30 UTC Fri Nov 26 2010
System restarted at 17:52:49 UTC Fri Nov 26 2010
System image file is "flash:c2800nm-advipservicesk9-mz.124-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2821 (revision 53.51) with 509952K/14336K bytes of memory.
Processor board ID FTX1048A34X
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2101
11-29-2010 08:04 AM
seems that someone has changed your config-register ...
I assume you want to have the image c2800nm-advipservicesk9-mz.124-25d.bin running on this router
- delete the IOS 15.0(1) release
- copy the IOS 12.48(25d) to the router as you have done initialy
- verify the integrity of this image with
- if it is ok, set the boot var to point to this image
- CHANGE the config-register with the command
config-register 0x2102
- verify this value to be shown at the end of the output of "show version"
- copy running to startup (wr mem)
- reload the router and (hopefully) be happy ...
11-29-2010 09:10 AM
Hi Martin,
The Register value was the problem. I am glad Router is running with the latest IOS.
Thanks a lot for the time and prompt Reply
11-29-2010 09:24 AM
Manish,
fine that I could help you! And here is also a link where the different config-register values and their meanings are listed :
