xtovski
Beginner
Cisco 2900 DHCP DNS integration
Hi everyone,
I am very confused how to integrate DHCP with DNS on 2900 so that DNS will resolve DHCP client names. I guess it should be pretty easy, but I just can't make it work. First of all, how to configure what DNS zone should be used for name resolution?
1 ACCEPTED SOLUTION
Router not a Full blown DHCP server / DNS Server, it can act as DHCP / DNS (personally i do not believe it does what you expecting).
That is the only alternative option you have to setup manually HOST to IP to resolve.
Not tested myself - good to test here
check the document :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dns/configuration/15-sy/dns-15-sy-book/Dynamic-DNS-Support.html#GUID-4AF4EC12-03D4-4083-8430-E45F03A06BB2
BB
How to Ask The Community for Help
5 REPLIES 5
marce1000
VIP Advisor
 - In general it's best not to rely on switches for the topic you describe but look for external appliances , albeit dedicated or not. Here is an example link :
                 https://social.technet.microsoft.com/wiki/contents/articles/51810.windows-server-integration-between-dns-and-dhcp.aspx
  Keeping switching and dns-dhcp separate helps in preventing dead-locks when providing network services.
 M.
balaji.bandi
VIP Master
Please clarify here, yuou have DHCP on router you like to reflect that in records, i think i never got success of the some how.
But deploying both on Windows DHCP and DNS can do do the trick, this is what most organisation do, some do with Inforblox.
https://docs.microsoft.com/en-us/troubleshoot/windows-server/networking/configure-dns-dynamic-updates-windows-server-2003
BB
Yes, router is the DHCP and DNS server,
I thought that
Router(config)# ip dhcp update dns both override
Will do the trick, however I get no result.
And currently I am forced to do manually
ip host hostA 192.168.1.2
BB
Yes, you are right. It is mission impossible.
But for my home lab it was a deal-breaker. So this Cisco is going Ebay.
