03-27-2011 01:38 AM
I have installed LMS 3.2 with DFM 3.2, but Cisco 2921 router is showing unknown device in DFM.DFM 3.2 will support cisco 2921 router?
Safwan
03-27-2011 08:48 AM
DFM 3.2 supports the 2921 today. You need to apply a device update first, though. Go to Common Services > Software Center > Device Update and check the boxes next to Common Services and DFM. Download and install all available updates.
03-28-2011 09:24 AM
Hi Joe,
I have installed the device update for both Common services and DFM but no luck, 2921 is unknown device in DFM.
With Regards,
Safwan
03-28-2011 10:18 PM
What is the sysObjectID of this router? After applying the update, did you remove and re-add the 2921 to DFM?
04-03-2011 05:10 AM
Hi Joe,
OID:1.3.6.1.4.1.9.1044, I have removed 2921 from DFM and added againg. But still DFM showing Unknown device.
04-03-2011 07:48 AM
Check NMSROOT/objects/smarts/conf/discovery/oid2type_Cisco.conf to confirm you see an entry for 1.3.6.1.4.1.9.1.1044. This should have been added as part of "Day1 DFMDeviceUpdates 3.0 Support". If you do not have this entry, then the DFM device update was not properly installed. We just release LMS 3.2 SP1 that includes this device update among other things. You should try installing it to see if that gives you 2921 support.
