08-15-2015 01:00 AM
Hi, please help me anybody. I have a Cisco 3560 switch running in IP ROUTING mode. It's running with c3560-advipservicesk9-mz.122-37.SE.bin operating system. I'm facing a problem with this device, as whenever I want to configure IP SLA, it's showing Unrecognized Command.
The following commands I want to type:
ip sla 1
icmp-echo 202.129.196.3
frequency 10
exit
ip sla schedule 1 life forever start-time now
But, while typing the commands, the output shows unrecognized command. Can any body help me with this, as which IOS I should have to install for this configuration?
Thanks in advance.
Solved! Go to Solution.
08-17-2015 12:54 AM
Hello Samrat
The IP SLA feature on your switch is supported on the Cisco IOS version 12.2(40)SE and later, so you should upgrade preferably to the latest 12.2(55)SE10
I recommend you have a look at the Cisco Feature Navigator to see which features are supported on your platform: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Best regards,
Martin
08-17-2015 12:54 AM
Hello Samrat
Best regards,
Martin
08-17-2015 03:10 AM
Thank you Martin, I'll do this..
