Hi there,
You simply need to configure an SVI on the switch and make sure the VLAN is reachable from where ever your connecting PC is, ie:
vlan 2
name MGMT_VLAN
int vlan 2
ip address 10.10.2.254 255.255.255.0
int gi1/0/1
switchport mode access
switchport access vlan 2
spanning-tree portfast
no shut
With the above config connect your PC to gi1/0/1, configure its wired interface with an address in the 10.10.2.0 /24 subnet and then SSH to 10.10.2.254 .
cheers,
Seb.
