Beginner
Cisco 3850 deleting from flash
We received a supposed new 48 port Catalyst 3850 PoE and it has a secure config on it.  I have tried to delete the nvram_config via the romon but the flash: is read only.  Is there a way to delete this or should we just sent this back saying why are you senting us used equipment?
13 REPLIES 13
Hall of Fame Guru
Re: Cisco 3850 deleting from flash
What is wrong with using the command "wr erase"?
Beginner
Nope doesn't work as I cannot get to switch#
I am trying to do this via switch:
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
tftp[19]: (read-write)
Flash is read-only
So for me to delete the config this will have to be changed to read-write
Is this possible?
Hall of Fame Guru
Look at the prompt. The switch is ROMmon.
Post the complete output to the command "dir flash:".
Beginner
switch: dir flash:
Directory of flash:/
23233 drwx 4096 .
2 drwx 4096 ..
23234 -rw- 2097152 nvram_config
23235 -rw- 2097152 nvram_config_bkup
23236 -rw- 82022500 cat3k_caa-base.SPA.03.07.03E.pkg
23237 -rw- 5653180 cat3k_caa-drivers.SPA.03.07.03E.pkg
23238 -rw- 36953096 cat3k_caa-infra.SPA.03.07.03E.pkg
23239 -rw- 46236992 cat3k_caa-iosd-universalk9.SPA.152-3.E3.pkg
23240 -rw- 28883852 cat3k_caa-platform.SPA.03.07.03E.pkg
23241 -rw- 123237184 cat3k_caa-wcm.SPA.10.3.130.0.pkg
23246 -rw- 4737 packages.conf
23243 drwx 4096 virtual-instance
46465 drwx 4096 vman_fdb
54209 drwx 4096 dc_profile_dir
54211 drwx 4096 wnweb_store
23245 -rw- 1236 packages.conf.00-
69698 drwx 4096 core
23247 -rw- 15938176 cat3k_caa-guestshell.16.03.08.SPA.pkg
23248 -rw- 22306936 cat3k_caa-rpbase.16.03.08.SPA.pkg
23249 -rw- 264563320 cat3k_caa-rpcore.16.03.08.SPA.pkg
23250 -rw- 9671296 cat3k_caa-srdriver.16.03.08.SPA.pkg
23251 -rw- 209654388 cat3k_caa-wcm.16.03.08.SPA.pkg
23252 -rw- 13439612 cat3k_caa-webui.16.03.08.SPA.pkg
46467 -rw- 518 bootloader_evt_handle.log
69699 drwx 4096 .prst_sync
77443 drwx 4096 .rollback_timer
69701 drwx 4096 gs_script
46468 -rw- 65568 memleak.tcl
85186 drwx 4096 .installer
46469 -rw- 736 vlan.dat
755220480 bytes available (892674048 bytes used)
switch:
Beginner
This is the banner that comes up:
Press RETURN to get started!
****************WARNING! DO NOT CONTINUE UNLESS YOU AGREE!!*****************
* This system is restricted solely to TSYS authorized users for legitimate *
* business purposes only. The actual or attempted unauthorized access, use *
* or modification of this system is strictly prohibited by TSYS. *
* Unauthorized users are subject to Company disciplinary proceedings *
* and/or criminal and civil penalties under state, federal, or other *
* applicable domestic and foreign laws. Users (authorized or unauthorized) *
* have no implicit or explicit expectation of privacy. The use of this *
* system may be monitored and recorded for administrative and security *
* reasons. Anyone accessing this system expressly consents to such *
* monitoring and is advised that if monitoring reveals possible evidence *
* of criminal activity, TSYS may provide the evidence of such activity to *
* law enforcement officials. All users must comply with TSYS Corporate *
* Instructions regarding the protection of TSYS information assets. *
User Access Verification
Username:
Hall of Fame Guru
boot flash:packages.conf
Highlighted
Beginner
Nope didn't work
Hall of Fame Guru
@morizawa wrote:
Nope didn't work
Console into the switch and enter the command again.
Post everything.  We want to see what the switch is doing.
Beginner
switch: boot flash:packages.conf
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Reading full image into memory....done
Reading full base package into memory...: done = 22306936
Bundle Image
Kernel Address : 0x53431388
Kernel Size : 0x34ec3d/3468349
Initramfs Address : 0x5377ffc5
Initramfs Size : 0x119e8b3/18475187
Compression Format: mzip
Bootable image at @ ram:0x53431388
Bootable image segment 0 address range [0x81100000, 0x81b8adc0] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x816903c0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
Final tar file: mcu_ucode_bundle_6_2_0.tar
Both links down, not waiting for other switches
Switch number is 1
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Wed 13-Feb-19 03:00 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
%INIT: waited 0 seconds for NVRAM to be available
Defaulting CPP : Policer rate for all classes will be set to their defaults
name Network Row2 - LAN
% Invalid input detected at '^' marker.
name Network Row2 - VOIP
Error: system-cpp-police-l2lvx-control is not a valid class in system-cpp-policy policy : Class rejected
police rate 1000 pps
vstack
%Log packet overrun, PC 0xAAAF58F7EC, format:
User:%s logged command:%s
Beginner
I hit enter and this is what comes up same thing:
Username:
Hall of Fame Guru
It's working fine.
What exactly are you trying to accomplish?
Beginner
I am trying to wipe the config that was left in the new switch that we have purchased and it is not letting me do this.
By all means keep sending me ideas but I do not have the resources to keep following up on this error made at Cisco's end.
If it's quick and easy then fine otherwise I will be sending these switches back
Hall of Fame Guru
Everyone's tags (1)
Content for Community-Ad
