06-01-2019 04:37 AM
Hi Friends.
I have problem with the Cisco router 4331 after upgrading the ROMMON firmware. after upgrade, the router cant boot and I get this message and the router reboot and reboot.
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
ISR4331/K9 platform with 8388608 Kbytes of main memory
media drive bootflash: not present
autoboot: boot failed, restarting...
Resetting .......
when I go to the ROMMON mode the router cant recognize the USB Flash and I cant do anything. there is no copy command and tftpdnld.
how can I boot this router.
the USB flash is formatted correctly and other router recognize that
the only command are these:
rommon 2 > ?
alias
boot
confreg
dev
dir
help
history
meminfo
repeat
reset
set
showmon
sync
token
unalias
unset
Best Regards.
06-01-2019 04:58 AM
06-01-2019 05:12 AM
Hi Edwin. thank you for your help.
06-01-2019 05:41 AM
06-01-2019 11:30 PM
There is no "copy" command.
I have only this commands:
rommon 2 > ?
alias
boot
confreg
dev
dir
help
history
meminfo
repeat
reset
set
showmon
sync
token
unalias
unset
06-01-2019 11:58 PM
06-01-2019 05:08 AM
06-01-2019 05:14 AM
Hi Leo.
thank you for answer.
rommon 10 > dir bootflash:
06-01-2019 05:19 AM
06-01-2019 05:20 AM
rommon 12 > dir flash:
media drive flash: not present
06-01-2019 05:39 AM
12-05-2019 09:50 PM
Hi Ateyi
You are encountering the error due to a bug below
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg37458/?rfs=iqvred
Issue boot command on rommon mode - It will boot with the available ios on the flash.
Once it boots, you need to upgrade the firmware to the unaffected like release 16.9(1r).
