Cisco 4331 Stuck in ROMmon mode
atiye.bigdeli
Hi Friends.
I have problem with the Cisco router 4331 after upgrading the ROMMON firmware. after  upgrade, the router cant boot and I get this message and the router reboot and reboot.
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
ISR4331/K9 platform with 8388608 Kbytes of main memory
media drive bootflash: not present
autoboot: boot failed, restarting...
Resetting .......
when I go to the ROMMON mode the router cant recognize the USB Flash and I cant do anything. there is no copy command and tftpdnld.
how can I boot this router.
the USB flash is formatted correctly and other router recognize that
the only command are these:
rommon 2 > ?
alias
boot
confreg
dev
dir
help
history
meminfo
repeat
reset
set
showmon
sync
token
unalias
unset
Best Regards.
17 Replies 17
Edwin Portillo
Hi my Friend,
You should try loading the IOS on a USB flash drive and force the router to boot via USB.
You can also feel it from Xmodem mode:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/rommon.html
Hi Edwin. thank you for your help.
I search for Xmodem command but I could not find the xmodem command.
There is no "copy" command.
I have only this commands:
rommon 2 > ?
alias
boot
confreg
dev
dir
help
history
meminfo
repeat
reset
set
showmon
sync
token
unalias
unset
If the "media drive" cannot be detected, then doing xmodem or booting from USB is of no use. At the end of the day, the router is royally "turfed".
No point fixing it but organize for an RMA.
Leo Laohoo
Post the complete output to the command "dir bootflash:".
Hi Leo.
thank you for answer.
rommon 10 > dir bootflash:
How about "dir flash:"?
rommon 12 > dir flash:
media drive flash: not present
RMA the appliance.
alexcharles
Hi Ateyi
You are encountering the error due to a bug below
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg37458/?rfs=iqvred
Issue boot command on rommon mode - It will boot with the available ios on the flash.
Once it boots, you need to upgrade the firmware to the unaffected like release 16.9(1r).
Alex,
It is not a bug. The router is loaded with SD-WAN firmware.
How to enter privileged mode in ROMMON ?
rommon 16 > priv
the priv mode is not enabled
I dont think there is a priv mode on rommon. It has to boot on an image then you can go to priv mode. Issue boot command.
