10-14-2016 03:45 AM
Hi All,
Can I have someone to urgently tell me why the switch isn't activating the ip routing. I have issued that command but when I do sh run Its not in effect?
the version of IOS is below:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.01.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 28-Jan-16 22:17 by prod_rel_team
Solved! Go to Solution.
10-17-2016 01:03 AM
im actually running one of these images on one of my 45s at access layer , the routing command is hidden
im on entservices as well but not seeing the same issues
#sh run all | i routing
ip routing protocol purge interface
ip routing
ip multicast-routing
#sh ver | i 8
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.08.01.E RELEASE SOFTWARE (fc2)
could you post the show interface vlan x for each vlan
show spanning-tree vlan x
sh vlan id x
sh run int vlan x
10-14-2016 05:24 AM
what exactly do you mean its not in effect ?
is routing not working when you configure it ? or do you mean you don't see it in running-config ?
if you cant see it in sh run it could be enabled by default if that's the case , try sh run all it can show the hidden default commands that are enabled
10-14-2016 05:50 AM
Hi Mark,
Ok I cant see on running-config, then if I configured interfaface of for example vlan 13 and 15 with ip addresses for vlan 13 and another subnet for vlan 15, then i connect a client machine to access port with vlan 13, I tried pinging the ip address for vlan 15 but its unreachable.
This shows like inter vlan routing is not working.
10-14-2016 05:55 AM
yes that's sounds as if something's off alright
the 2 vlan interfaces are up , can you ping directly between them on the actual router cli that will rule out intervlan routing if its the problem ? if they can ping between the interfaces intervlan is working and you probabaly have some other issue
whats the license level your on ? show license
10-14-2016 07:06 AM
Hi Mark,
Unfortunately am out from the customers site, but I remember I saw something like:
license:permanent while it was booting up.
Please also with ideas on how to tackle the issue.
May be will post the result tomorrow but one that is on Sunday 16/10/2016.
10-14-2016 07:14 AM
1 first you really need to confirm if it is intervlan issue by pinging between vlan interfaces rather than hosts , this will confirm exactly
2 if that's working then there is something off with your pc setup or access port setup ,maybe typo in TCP/IP settings or ports gone err-disabled at access side
3 Check spanning tree make sure ports are all forwarding and not blocking for some reason too
if routing is enabled when you do show ip route even if nothings really configured but routing enabled you should see ---Gateway of last resort -- in the output
if its still acting as layer 2 you will see --Default gateway is --- this will confirm if switch is running at layer 3 or 2 even if you cant see ip routing in config
These switches are layer 3 so I doubt its not able to route , but if you only have lan services license you cant route its blocked , you will need at least ipbase or ipservices for ip traffic so confirm the license
let me know what you find when you get access we can go from there , try collect the outputs and post them so we can see what your seeing
10-16-2016 02:39 AM
Hi Mr. Mark,
below are the outputs:
1. The switch itself cannot ping its vlan interfaces configured with ip addresses.
output for show license summary:
Index 0 Feature: entservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 1 Feature: ipbase
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 2 Feature: lanbase
Period left: 1513 weeks 1 day
Index 3 Feature: internal_service
Period left: 0 seconds
Output for show ip route:
#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
switch#
10-17-2016 12:54 AM
your on full license and routing is enabled as per your output
both interfaces are fully up and you still cant ping between them ? no spanning-tree issues in logs for those vlans ?
never seen this before as these pings are on same data plane in the switch , these switches are known for having a few buggy versions of ios-xe but the basics usually all work , do you see any packets being dropped in the vlan interface when you check them ?
if everything looks fine interfaces are up nothing irregular in the logs I would change the ios-xe verion to an MD release or a safe harbour release try one if them instead
10-17-2016 01:03 AM
ip routing
#sh ver | i 8
sh vlan id x
sh run int vlan x
10-17-2016 01:11 AM
Hi Mr. Mark,
Thanks a lot for your support I realized that I had to connect the 4500x switch to an access switch so that it can bring the svi online.
Tested and everything worked ok.
10-17-2016 01:17 AM
ah very good least its working now thanks for the update
