03-16-2011 07:06 AM
Hello.. does anyone know the meaning of this log message in a 7609 router - "SP: FAILED to write to DS1338 RTC device"?
So far as I can tell DS1338 RTC is supposed to be a (linux-related?) clock but I don't see how that's related to the router.
Thanks.
04-01-2011 01:08 AM
I am also facing the same issue. did you find any solution to this.
BR//Rajiv
04-04-2011 07:40 AM
Unfortunately no. I'm assuming it's related to some kind of Unix clock system. Still getting the error and no idea how to troubleshoot. Not a lot of related info available.
Please update if you find anything.
Thanks.
06-21-2011 05:55 AM
I also facing the same issue.
I already replace all sup and CK7600. but still facing.
Have someone sloved ?
06-27-2011 09:16 AM
I haven't found anything as yet. Still getting the same error but it doesn't seem to be affecting the router. Am still searching for information.
06-27-2011 06:06 PM
Hope you complete in soon
I am going to replace the chassis 7609 in soon and report you back.
My customer very serious about the log.
02-08-2012 08:51 AM
Noticed the same log messages in 7609.
Did anyone found the reason? Is it a chassis problem?
04-25-2012 10:46 AM
I experienced this as well. Check out BugID CSCts20541
The clock on my RP and SP looked fine.
05-19-2017 08:06 AM
SP-STDBY: FAILED to write to DS1338 RTC device
Conditions:
None
Workaround:Disable Logging.
More Info:There is no operational impact due to this issue.
