Cisco 891F web interface
mnu_pd2021
I have a new Cisco Router 891F. When I connect to it via web-browser it shows a limited menu (attached).
I found an old computer with Windows 7 and i tried with Firefox v20 but the menu is the same.
What should I do in order to have the full web interface ?
Thanks in advance
you need to get a configuration utility to configure the device :
https://www.cisco.com/c/en/us/products/cloud-systems-management/router-web-setup-tool/index.html
BB
6 Replies 6
balaji.bandi
can you post show version and dir output
BB
 Ok, i attached the results.
BB
OK, thank you again for your support.
Unfortunatelly I cannot download this software, I dont have a service contract with Cisco and the supplier from where I bought the router cannot help me.
if this is a simple configuration one time - we can help to build one for you - if you can provide the details.
BB
it's ok, i will try to find the software or keep the CLI as the only option to configure it.
