cisco 897 vag lte not working
COthi#sho running-config
Building configuration...
Current configuration : 2938 bytes
! Last configuration change at 02:21:34 UTC Fri Nov 29 2019
version 15.6
hostname Punthi
boot-start-marker
boot-end-marker
enable secret 5 ABC
enable password ABC
no aaa new-model
no process cpu autoprofile hog
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C897VAG-LTE-LA-K9 sn FGL2136922L
redundancy
controller VDSL 0
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0
ip address negotiated
no ip unreachables
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 30
dialer watch-group 1
dialer-group 1
async mode interactive
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
no cdp enable
interface GigabitEthernet1
no ip address
shutdown
no cdp enable
interface GigabitEthernet2
no ip address
shutdown
no cdp enable
interface GigabitEthernet3
no ip address
shutdown
no cdp enable
interface GigabitEthernet4
no ip address
shutdown
no cdp enable
interface GigabitEthernet5
no ip address
shutdown
no cdp enable
interface GigabitEthernet6
no ip address
shutdown
no cdp enable
interface GigabitEthernet7
no ip address
shutdown
no cdp enable
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended NAT
permit ip 10.0.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
exec-timeout 0 0
no modem enable
length 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
password ABC
login
transport input none
scheduler allocate 20000 1000
end
13 Replies 13
Ben Walters
Level 3
Level 3
It looks like you may be missing the LTE SIM data-profile command under the controller cell 0 config
If you haven't done so already to need to define a cellular profile that uses your ISP's APN.
COthi# cellular 0 lte profile create <number> <APN>
Then you set the data-profile on cell controller 0
COthi(config-controller)# lte sim data-profile <number> attach-profile <number> slot <SIM slot>
Once you have done that, or if you have done that already in your config you can check the status with show cell 0 all
try the config below:
version 15.6
hostname Punthi
boot-start-marker
boot-end-marker
enable secret 5 ABC
enable password ABC
no aaa new-model
ip cef
no ipv6 cef
redundancy
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
interface Cellular0
no ip unreachables
ip nat outside
encapsulation slip
dialer in-band
dialer pool-member 1
dialer-group 1
routing dynamic
interface Cellular1
no ip address
encapsulation slip
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
ppp authentication pap callin
ppp pap sent-username yourusername password 0 yourpassoword
ppp ipcp dns request
no ip address
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Vlan1
ip nat inside
==> no shutdown
no ip http server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 10.0.0.0 0.0.0.255
ipv6 ioam timestamp
control-plane
vstack
line con 0
exec-timeout 0 0
no modem enable
length 0
line aux 0
line 2
no exec
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
password ABC
login
end
Its work few das.. I was checking with different sims and stops working ,, may be i have chnaged some thing.. Below is ruuning config,,
Note:- Its not taking   dialer pool-member 1 in interface cell0
please advise:-
Router#
Router#
Router#sho run
Router#sho running-config
Current configuration : 2690 bytes
! Last configuration change at 06:22:54 UTC Fri Dec 20 2019
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
redundancy
controller VDSL 0
lte sim data-profile 1 attach-profile 1 slot 0
interface ATM0
no ip address
shutdown
interface Cellular0
no ip address
encapsulation slip
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ipv6 ioam timestamp
control-plane
vstack
line con 0
no modem enable
line aux 0
line 2
no exec
stopbits 1
line 3
script dialer lte
no exec
rxspeed 150000000
txspeed 50000000
line 8
no exec
line vty 0 4
login
end
Router#
Router#
what are your options in cellular interface configuration mode ?
Router#conf t
Router(config)#interface cellular 0
Router(config-if)#?
Router(config-if)#?
Interface configuration commands:
aaa Authentication, Authorization and Accounting.
access-expression Build a bridge boolean access expression
arp Set arp type (arpa, probe, snap), timeout, log options or
packet priority
asp ASP interface subcommands
async Async interface parameters
authentication Auth Manager Interface Configuration Commands
autodetect Autodetect Encapsulations on Serial interface
autonomic Autonomic Networking
bandwidth Set bandwidth informational parameter
bgp-policy Apply policy propagated by bgp community string
bridge-group Transparent bridging interface parameters
bsc BSC interface subcommands
bstun BSTUN interface subcommands
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
crypto Encryption/Decryption commands
cwmp Configure CPE WAN Management Protocol(CWMP) on this
interface
cws Configure Cloud Web Security
dampening Enable event dampening
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
dialer Dial-on-demand routing (DDR) commands
dialer-group Assign interface to dialer-list
domain Specify a domain
dot1q dot1q interface configuration commands
dot1x Interface Config Commands for IEEE 802.1X
down-when-looped Force looped serial interface down
encapsulation Set encapsulation type for an interface
eou EAPoUDP Interface Configuration Commands
ethernet Ethernet interface parameters
exit Exit from interface configuration mode
flow-sampler Attach flow sampler to the interface
full-duplex Configure full-duplex operational mode
h323-gateway Configure H323 Gateway
half-duplex Configure half-duplex and related commands
help Description of the interactive help system
history Interface history histograms - 60 second, 60 minute and
72 hour
hold-queue Set hold queue depth
ignore ignore signals or crc(if applicable)
ip Interface Internet Protocol config commands
iphc-profile Configure IPHC profile
ipv6 IPv6 interface subcommands
lisp Locator/ID Separation Protocol
llc2 LLC2 Interface Subcommands
load-interval Specify interval for load calculation for an interface
logging Configure logging for interface
mab MAC Authentication Bypass Interface Config Commands
mace Measurement Aggregation and Correlation Engine
macro Command macro
metadata Metadata Application
mpls Configure MPLS interface parameters
mtu Set the interface Maximum Transmission Unit (MTU)
nat64 NAT64 interface commands
netbios Use a defined NETBIOS access list or enable name-caching
no Negate a command or set its defaults
ntp Configure NTP
onep Configure onep settings
ospfv3 OSPFv3 interface commands
peer Peer parameters for point to point interfaces
performance Global performance monitor configuration
port-tagging Allow port tagging on an interface
pulse-time Force DTR low during resets
rate-limit Rate Limit
redundancy RG redundancy interface config
routing Per-interface routing configuration
serial serial interface commands
service-policy Configure CPL Service Policy
service-routing Service Routing in Interface Mode
shutdown Shutdown the selected interface
smds Modify SMDS parameters
snapshot Configure snapshot support on the interface
snmp Modify SNMP interface parameters
source Get config from another source
srlg Interface Shared Risk Link Group config commands
stun STUN interface subcommands
timeout Define timeout values for this interface
topology Configure routing topology on the interface
transmit-interface Assign a transmit interface to a receive-only interface
tx-ring-limit Configure PA level transmit ring limit
user-group Interface-User-group Association
utd UTD support on this interface
vrf VPN Routing/Forwarding parameters on the interface
waas WAN Optimization
zone-member Apply zone name
Router(config-if)#
Hello I posted the options but there lot of,, Please check the best config,,i tried with some changes but did not work.
Hello, Now able to ping dns from router but not from system(LAN),,getting 1/30 reply from system to dns..
pls support..
Router#ping 8.8.8.8 source vlan 10 repeat 100
Sending 100, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.0.0.1
Current configuration : 3044 bytes
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool lantest
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 61.9.194.49
ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Cellular0
no ip unreachables
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
routing dynamic
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
switchport access vlan 10
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ipv6 ioam timestamp
control-plane
vstack
line con 0
no modem enable
line aux 0
line 2
no exec
stopbits 1
line 3
script dialer lte
no exec
rxspeed 150000000
txspeed 50000000
line 8
no exec
rxspeed 150000000
txspeed 50000000
line vty 0 4
login
end
Router#
try and manually create Vlan 10:
Router#conf t
Router(config)#vlan 10
still Not able to ping dns from system while pinging from router with source vlan 10
HI, please verify as still not working..
looking at one of your previous posts:
--> Its work few das.. I was checking with different sims and stops working ,, may be i have chnaged some thing.
I think your best option might be to 'wr erase' the configuration, then reload the device and start from scratch, meaning, entering the entire config again as if it were a new device...
I have done that already but still missing something which is not allowing to work.
can u please check the above config and suggest
Router#ping 8.8.8.8 source vlan 1 size 1500
Sending 5, 1500-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/76/108 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/73/88 ms
Router#ping 8.8.8.8 source vlan 1 size 1501
Sending 5, 1501-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
