Cisco 9300 Switch GUI VLANs does not match CLI
Bjorn Dirchsen
I'm trying to document our Cisco switch configuration.
But it seems that the GUI and the CLI does not display the same information which I simply dont' understand.
E.g. In the GUI under Configuration / Interface / Ethernet, I have configured port 48 to forward VLANs 1, 2 and 40:
But if I list the VLANs using the CLI, port 48 is not listed under any VLANs:
CS01#show vlan
VLAN Name Status Ports
1 default active
Te1/1/4, Ap1/0/1, Gi2/0/10
Te2/1/1, Te2/1/2, Te2/1/3
2 VLAN0002 active
Gi2/0/45, Gi2/0/46, Gi2/0/47
Gi3/0/4, Gi3/0/9, Gi3/0/13
40 VLAN0040 active
Gi1/0/37, Gi1/0/38, Gi1/0/39
Gi1/0/40, Gi1/0/42, Gi1/0/43
Gi4/0/6, Gi4/0/48
Which settings are the correct ones, and why does it display different values depending on where you look from?
Thanks, Bjorn
@Bjorn Dirchsen this is correct. the port you have in GUI is gi 2/0/48 which is trunk port. trunk ports not showing in #show vlan command. to check trunk ports, try #sh int trunk
Good luck
KB
5 Replies 5
Good luck
KB
Thanks @Kasun Bandara!
That makes kinda sense (I'm not a Cisco guy so forgive my lack of knowledge)
sh int trunk gave me the information, I needed:
Port           Vlans allowed on trunk
Gi2/0/44       2,40
Gi2/0/48       1-2,40
Gi3/0/2        1-2
Thanks!
pieterh
in addition to Kasun's reply: you are comparing GUI-configuration with operational status
you should compare with "show running-configuration interface ....."
Show interface trunk <<- this will show you if your config correct or not' show vlan not wotk for trunk port it only for access port
Bjorn Dirchsen
Gi2/0/44       2,40
Gi2/0/48       1-2,40
Gi3/0/2        1-2
Thanks!
