03-05-2009 07:11 AM
has anyone managed to use Microsoft SQL Server as ODBC for CNS CAR 4.X?
Currently we are using mysql for accounting, but we want to migrate. unfortunately cisco help only describes oracle and mysql.
http://www.cisco.com/en/US/docs/net_mgmt/access_registrar/4.2/user/guide/accountg.html
03-11-2009 06:16 AM
Cisco AR 4.0 provides support for MySQL to query user records from a MySQL database and enables you to write accounting records into MySQL when using Oracle accounting. Cisco Access Registrar 4.0 has been tested with MySQL 4.0.18 and MyODBC 3.51.06 (reentrant). For the Cisco AR server to use MySQL, you must create and configure an ODBCDataSource object of type myodbc and a RemoteServer object set to protocol odbc.
03-16-2009 07:03 AM
Has anyone managed to make it work with Microsoft SQl?
03-23-2009 03:13 AM
I found that in order to connect from solaris or Linux to a Microsoft SQL Server you should use freetds (http://www.freetds.org/).
Anyone tried it?
