I have a Cisco Aironet 1815t Series for connecting to my workplace’s network from home. I can connect it directly to my router fine, however when I try to connect it to my router through a TP link Ethernet switch, it gets stuck on cycling red, amber and green (Discovery/join process is in progress). I have plugged everything out and back in, switched Ethernet ports, changed Ethernet cables, still the same issue. It did work before so not sure why it is now having issues. Any ideas?
