Cisco APIC-EM Appliance
csco10675262
I have a query on the Cisco APIC-EM appliance; I would like to ask if it is possible to upgrade or replace the VNIC 1225T that ships with it? I would like to change it to VNIC 1225 for sfp+ support instead of 10BaseT however not too sure if it is supported?
Based on my understanding, the appliance is based on UCS C220 and it supports a variety of PCIEs however I am not too sure if it supports component customization for the APIC-EM Appliance.
Any suggestion is appreciated!
Mark Elsen
 - Changing hardware components on an appliance is an on-your-own-risk operation ; things may work , but the configuration becomes unspported.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
M.
       Beauty and terror
      Just keep going
       No feeling is final
Appreciate for the help and update. I have checked with Cisco for confirmation and they have informed that its still supported so long its a product which may support it. In this case UCS C220 and its components.
Thanks.
