Cisco AS5350 call logging
Phil Curwood
Hi Guys,
There is a need for us to be able to extract the call details (modem calls only) from a Cisco AS5350 device.
We want to be able to report on the following:
Number of inbound calls
The times these calls established
The call duration
The rate these calls 'trained' to
The number of calls that failed to train
I have been looking at using the calltracking feature by outputting this data to a syslog server however all I seem to be getting from the device is SNMP OID details as opposed to the raw call data.
Can you let me know the easiest way to extract the above data using syslog?
Thanks.
Robbie.
Phil Curwood
Does anyone out there have any knowledge of these old Cisco devices then? Doesn't look great with no replies so far :(
